Code Block |
// Fatal error freeing exporter memory. // // There was a fatal error building the scene for V-Ray. // // There was a fatal error updating the scene for V-Ray. // // Fatal error clearing key frames. // // Fatal error baking node. // // Fatal error rendering scene. // |
If you see a Fatal Error message when rendering, contact the Chaos support team with information on how to reproduce the crash. Usually, sharing a scene and the V-Ray logs, along with any steps to reproduce the issue helps the team identify and fix the problem.
If you want to make the selection permanent, it is recommended to use the VRAY_GPU_PLATFORMS environment variable. See the Environment variables page and the Getting Started with Environment Variables page for more details.
V-Ray doesn't support frames at non-integer times in DR
