V-Ray for Maya supports the use of tiled OpenEXR (.exr) and TIFF (.tx, .tex) files with MIP maps. This allows V-Ray to load just parts of a given texture during rendering in order to save memory. When you are using tiled OpenEXR or TIFF files with mipmaps V-Ray automatically recognizes this and loads the appropriate tiles during rendering instead of just loading the whole texture. In order to convert many regular image file formats into tiled OpenEXR files you can use the img2tiledexr tool that comes with V-Ray. To convert to tiled TIFF files, the maketx tool from the OpenImageIO library can be used. Using tiled OpenEXR and TIFF files also allows V-Ray to dynamically unload some of the tiles when memory is needed for something else. The loading and unloading of the tiles works the same way as the loading and unloading of dynamic geometry and by default is stored in the same dynamic memory pool. You can set a dynamic memory limit in the System rollout of the Settings tab in the Render Settings dialog. You can also designate a separate cache for tiled textures by using the VRAY_TEXTURE_CACHE environment variable, and assign to it the desired maximum size of the cache in megabytes (see the section on Environment Variables for  as well as the Getting Started with Environment Variables page for more details).
Using Tiled OpenEXR and TIFF Files for Displacement
