The Body Forcecreates a force to pull the fluid toward or away from a geometry object.
A positive Strength value produces a force that pulls fluid toward a geometry objectthat , and can be used for giving shape to make the fluid . The form the shape of the geometry; for example, making a liquid simulation form the shape of a letter, number, or logo for an interesting effect.
UI Text Box
type
note
Note that the force is pronounced outside the body, but the inside is replaced with a mechanism that suppresses the fluid's escape.
Meanwhile, negative Strength values repel the fluid away from the geometry object.
UI Expand
title
UI Path: ||Phoenix FD|| > Create > Body Force
width
50%
Body Force Object
Body Object | body – Specifies the selection set used as an attractor.
