Distributed rendering is a technique for distributing a single render job within a single frame across many computers in a network. There are different approaches to doing this, but the main concept is to reduce the render times by dividing different parts of the rendering pipeline and giving each participant different parts of the job.
Organization
V-Ray divides the frame into regions and spreads them across the participants in the distributed rendering. This is done completely through TCP/IP protocol which is the standard protocol of the Internet and thus the most common protocol that is supported by the hardware. V-Ray itself does not need an additional file or directory sharing (note that you may actually need some file/directory sharing for the bitmaps or other additional files used during rendering). The distribution management is divided into Render Clients and Render Servers.
UI Text Box | ||
To use V-Ray distributed rendering you need to have both V-Ray for 3ds Max and Autodesk 3ds Max installed on both the render client and the server machines. When using the V-Ray GPU render engine, а V-Ray Standalone (or V-Ray for 3ds Max) installation is sufficient for each server machine. |
Render Clients
The render client is the computer from which the rendering is started. It divides the frame into rendering regions and spreads it across the Render Servers. It distributes data to the render servers for processing and collects the results.
UI Text Box | ||
Distributed Rendering setup for the render server machines is set accordingly to the preferred V-Ray renderer. V-Ray requires V-Ray DR spawner to be run on the render server machines, while V-Ray GPU requires V-Ray GPU Render Server or V-Ray Standalone (with server command). |
Check how to Set Up V-Ray Render Service
Check how to Set Up Distributed Rendering
Fancy Bullets | ||
