This page provides information on the Phoenix Grid Texture.
The Phoenix Grid Texture can be created from the Hypershade. It loads and exposes a Grid Channel of a selected Phoenix Simulator as a procedural texture, which can then be used to shade the simulation wherever colors are needed.
For example, this texture can be plugged into the texture slots of a material as color or opacity, and used to shade the surfaces of liquids or meshes in general, that were exported with an RGB Grid Channel. For example, if If you want to mix together liquids, for example, with multiple RGB colors emitted from different Liquid Sources, the Grid Texture can be used to read and transfer the RGB colors to the Liquid mesh's material for shading.
UI Text Box | ||
UI Path: ||Hypershade|| > Create panel > Maya section > 3D Textures |
