Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVS4EDIT:V-Ray Standalone Command Line Options
The V-Ray Standalone tool is a command-line rendering tool supporting V-Ray's native .vrscene file format.
Textboxcard
CardPageLinkDenoiser Tool
Denoiser Tool
A command-line utility that can be used to denoise still images or animations outside of SketchUp.
Textboxcard
CardPageLinkConvert Images to Tiled EXRs
The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for compositing or for other adjustments and fine-tuning at the render element level.
Textboxcard
CardPageLinkIrradiance Map Viewer
The Irradiance Map viewer tool allows you to navigate around a 3D projected version of a scene to view where GI samples were taken during the rendering process.
Textboxcard
CardPageLinkOBJ GEO PLY to .vrmesh converter
The ply2vrmesh command-line utility can convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc, and .vrscene files to .vrmesh files for rendering with V-Ray through V-Ray Proxy Objects.
Textboxcard
CardPageLinkV-Ray Image to EXR Converter
The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
Textboxcard
CardPageLinkV-Ray mesh viewer
V-Ray mesh viewer
The V-Ray Mesh Viewer is a tool that previews V-Ray mesh and alembic files. It can display both static and animated meshes.
Textboxcard
CardPageLinkPlugininfo Tool
Plugininfo Tool
The plugininfo tool generates documentation for all V-Ray plugins. It can be used to list all V-Ray plugins or to display a detailed information for a specific one by using the commands from the Options table.
Textboxcard
CardPageLinkFilter Generator Tool
The Filter Generator is a tool for composing filters (HDR images in *.hdr format). It is specially designed to produce filters for the Lens Effects.
