This page includes a list of external tools that come with V-Ray.
The following tools and utilities come installed with V-Ray for Rhino. For more information about each tool, see its individual page.
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1100px
Columns1repeat(3, 1fr)
Columns1width1740px
Columnsrepeat(4, 1fr)
Columns2width1290px
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVS4EDIT:V-Ray Standalone Command Line Options
The V-Ray Standalone tool is a command-line rendering tool supporting V-Ray's native .vrscene file format.
Textboxcard
CardPageLinkDenoiser Tool
Denoiser Tool
A command-line utility that can be used to denoise still images or animations outside of SketchUp.
Textboxcard
CardPageLinkIrradiance Map Viewer
The Irradiance Map viewer tool allows you to navigate around a 3D projected version of a scene to view where GI samples were taken during the rendering process.
Textboxcard
CardPageLinkOBJ GEO PLY to .vrmesh converter
The ply2vrmesh command-line utility can convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc, and .vrscene files to .vrmesh files for rendering with V-Ray through V-Ray Proxy Objects.
Textboxcard
CardPageLinkV-Ray Image to EXR Converter
The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
Textboxcard
CardPageLinkV-Ray mesh viewer
V-Ray mesh viewer
The V-Ray Mesh Viewer is a tool that previews V-Ray mesh and alembic files. It can display both static and animated meshes.
Textboxcard
CardPageLinkPlugininfo Tool
Plugininfo Tool
The plugininfo tool generates documentation for all V-Ray plugins. It can be used to list all V-Ray plugins or to display a detailed information for a specific one by using the commands from the Options table.
Textboxcard
CardPageLinkFilter Generator Tool
The Filter Generator is a tool for composing filters (HDR images in *.hdr format). It is specially designed to produce filters for the Lens Effects.
