This section contains information about the lighting nodes components in V-Ray for Grasshopper.
width60%
The Lighting tab displays all the V-Ray lights nodescomponents. They are the following: V-Ray Light Rig Dome,   V-Ray Light Rig SimpleV-Ray Light Rig Sun System, V-Ray Dome Light, V-Ray IES Light, V-Ray Light RectangleDirectional, V-Ray Light SphereMesh, V-Ray Light Omni, V-Ray IES Light Rectangle, V-Ray Light SpotSphereand V-Ray Light DirectionalSpot.
UI Text Box
typeinfo
Note that all lights attached to the V-Ray Render node component are exported through the Render in Project node component if connected.
width5%
width35%
Image Modified
