Code Block | ||
vray_adv_5200060000_maya20xx_x64.exe -gui=0 |
Code Block | ||
vray_adv_5200060000_maya20xx_x64.exe -gui=0 -configFile="C:\config.xml" -quiet=1 |
If you do not specify the -quiet=1 option, the installer will ask for confirmation of each variable before proceeding.
macOS
In the terminal navigate to the location where you have extracted the vray_adv_5200060000_maya20xx_mavericks_x64.app file
Using the cd command navigate inside the .app file and go to vray_adv_5200060000_maya20xx_mavericks_x64.app/Contents/MacOs
In the terminal enter:
./run_installer -gui=0You will be prompted for your password – enter it.
Follow the instructions of the installer and setup the installation in the way you want it to be installed on all machines.
A file named config.xml is created in the folder of the .app file
You can now install V-Ray on all machines by navigating to vray_adv_5200060000_maya20xx_mavericks_x64.app/Contents/MacOs and using the command:
./run_installer -configFile="config.xml" -gui=0 -quiet=1 -ignoreErrors=1
To perform a silent install first run the installer with the “ -gui=0 ” argument:
./vray_adv_5200060000_maya20xx_linux_x64 -gui=0
./vray_adv_5200060000_maya20xx_linux_x64 -configFile="config.xml" -gui=0 -quiet=1 -ignoreErrors=1
