width62%
The Multi Matte ID Render Element provides a mask for individual objects and/or materials, based on the Multi Matte IDs that have been added as Extra V-Ray Attributes.
The Multi Matte ID Render Element contains no shading information at all, and only contains blocks of color that correspond to each Multi Matte ID . It uses the Multi Matte ID set when the Material ID attribute is added to a material.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Multi Matte ID
width25%
width50%
Multiexcerpt include
MultiExcerptNameRE
PageWithExcerptRender Elements
width25%
Image Removed
width5%
width33%
Here's the workflow for setting up and using the Multi Matte ID Render Element:
width62%
Fancy Bullets
typecircle
  • Select the material in the Hypershade that a Multi Matte ID Render Element is needed for.
  • Add
width62%
 Add
  • the Material ID
attribute
  • attribute from Attributes > VRay > Material ID.
width5%
width33%
Image Removed
width62%
5%
width
  •  Set the Multi Matte ID to the required value. Note: each number corresponds to a different color.
width62%
 Open Render
width33%
Image Removed
  •  Open the Render Settings and go to the Render Elements tab and from
the Available
  • the Available render elements add a Multi Matte ID render element.
width5%
width33%
Image Added
Image AddedImage Removed
Common Uses
A typical usage of this render element, is to use the colors produced in the Multi Matte ID to produce a mask or alpha channel in post production that covers everything with that Multi Matte ID.
