The Coat Filter Render element is analogous to the is analogous to the Reflection Filter Render Element.
The Coat Filter Render Element stores reflection information calculated from the the VRayMtl Coat Layer. Surfaces with the Coat Amount parameter set to 0 will contain no information in the render pass and will therefore render as black.
UI Expand
titleUI Path: ||Display Render Settings button|| > Render Elements tab > Coat Filter
width40%
Multiexcerpt include
MultiExcerptNameRE
PageWithExcerptRender Elements
width60%
Image Removed
Attributes
width60%
Enabled When enabled, the render element appears in the VFB.
Deep output – Specifies – Specifies whether to include this render element in deep images.
Filename suffix – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.SheenFilter.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Denoise – Enables the render element's denoising, provided the Denoiser render element is present.
width5%
width35%
