Custom Attributes From Text Files
UI Text Box | ||
Custom Attributes from text files are available only with V-Ray 6 for Maya, Beta. |
The extra prefix attributes are a set of three text (.txt) files containing key-value definitions, which can be used to add dynamic attributes to Maya, V-Ray or 3rd party nodes. The default set of files, which are shipped with the installation are located inside the scripts folder of the V-Ray for Maya installation. It is possible to supply a custom set of attribute files. V-Ray will use the paths, specified by the VRAY_FOR_MAYA_SHADERS environment variable to search for such custom files. The default attribute files can be used as an example but should not be modified.
