The VFB can be controlled programmatically in two ways: the first is using various environment variables, and the second is using the vray vfbControl command.
The vray vfbControl commands are supported in batch rendering mode. Note that this feature is in V-Ray 6 for Maya, Beta only!
From MEL script
The vray vfbControl command modifies the various aspects of the VFB. Commands follow the following structure:
