UI Expand
expandedtrue
titleUI Path: V-Ray Menu > V-Ray Enmesh
width10%
width40%
V-Ray menu > V-Ray Enmesh
width10%
width40%
||V-Ray Shelf|| > Create V-Ray Enmesh button
Create Enmesh
width55%
Select the meshes you want to turn into reference geometry. Then, select the source geometry.
Create V-Ray Enmesh from the shelf button or from V-Ray menu > V-Ray Enmesh.
The reference geometry is connected to a set called VRayEnmeshRefs. It can be accessed and edited from the Connection Editor or by using the arrow next to the Objects parameter in the Enmesh node’s Attributes. You can apply multiple reference geometries. For more information, see the Reference Geometries example.
The source geometry is connected to another set called VRayEnmeshSources. It can be accessed and edited from the Connection Editor or by using the arrow next to the Source Mesh.
Note that only one mesh can be used as a source. The source geometry is initially invisible in the render. That can be changed by disabling the Force Invisible Source option.
A gizmo is created. If the gizmo needs rescaling, use the Fit in Object Space button to rescale the gizmo exactly around the mesh, and the Crop Box X/Y/Z parameters - for further adjustment of the size, if needed. The tiling and randomization parameters can be used for various effects.
UI Text Box
typenote
Make sure the gizmo covers the reference object completely to see proper result.
UI Text Box
typenote
Try to avoid unnecessary big gizmos with lots of empty space, especially with Crop Box Y, as they slow down the render and do not actually change the final render result.
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/TESUA7FxxHM" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Create V-Ray Enmesh and assign the reference object using the Relationship Manager
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/VmFyAnvEens" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Create V-Ray Enmesh from selection
Basic Parameters
width55%
Reference Objects – Shows the set containing the objects used as reference meshes.
Source Mesh – Shows the set containing the mesh used as a source.
Force Invisible Source – When enabled, the Source Mesh is invisible.
Crop Box X/Y/Z – Sets the gizmo size along the X/Y/Z axis.
Height % – Sets the VRayEnmesh height based on the Crop Box Size Y value. 100% means it uses original crop box height.
Height Offset % – Sets the VRayEnmesh geometry offset along the surface normals based on the Crop Box Y size.
Fit in Object Space – Clicking on this option positions the Enmesh gizmo in the viewport exactly around the reference object.
Use Mesh UVW Mapping – Uses the source mesh UVW for shading instead of the Surface UVW. This option is disabled by default.
Use Proxy Mesh IDs – Uses Proxy Mesh IDs for shading the patterned surface if a VRayMultiSubTex or MultiSubObject are used.
width5%
width40%
Tiling Options
width55%
Tiling U/V – Sets a pattern tiling in UVW space. Use these parameters according to your UVs size.
Offset U/V – Sets a pattern offset in UVW space.
Random Offset U/V – Uses the static UVW offset as base and adds it when calculating the randomization effect.
Rotation – Sets a pattern rotation in UVW space.
Use Random Rotation Steps – Makes Random Rotation parameter be based on 360/X, where X is steps count. For example, if Random Rotation is set to 4, the pattern mesh is randomly rotated on a 90 degrees step (360/4) with a 30 degrees offset - 30, 120, 210, 300, 390 (30).
Map Channel – Uses the set map channel for the surface geometry.
width5%
width40%
