changes.mady.by.user Kristin Ivanova
Saved on Apr 28, 2021
changes.mady.by.user Kristina Gaytandzhieva
Saved on Sep 28, 2022
The The Object ID Render Element creates selection masks based on Object ID that shows each object (by Object ID) in a solid unshaded color.
UI Path: ||V-Ray|| > Render Elements > Object ID
How to add a render element to a scene
Enable Deep Output – When enabled, the render channel is rendered in the V-Ray Virtual Frame Buffer.
Image RemovedImage Added
