The Shadows Render Element works as a reverse mask for shadows. It is a color image that can be used to lighten, darken or tint shadows. Shadows Shadows can be lightened in the composite by adding this render element, or darkened by subtracting this render pass from the final composite.
The Shadow render element is the product of multiplying the Raw Shadow Render Element with the Diffuse Filter Render Element in the composite.
UI Path: ||V-Ray|| > Render Elements > Shadow
(How to add a render element to a scene)
Multiexcerpt include
MultiExcerptName
AddBackground
PageWithExcerpt
Atmospheric Effects RE
Image Removed
width
5%
width
33%
Properties
width
62%
Enable Deep Output– – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in theColor mapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
