width62%
The Raw Shadow Render Element stores information about cast shadows calculated from the lighting in the scene.  It It is a "reverse" image in the sense that white areas indicate shadows while black areas indicate no shadow.
UI Path: ||V-Ray|| > Render Elements > Raw Shadow
width5%
width33%
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
Image Removed
How to add a render element to a scene
Properties
width62%
Enable Deep Output –  – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color mapping rollout of the V-Ray tab in the Render Settings window to this render element.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width33%
Image RemovedImage Added
