The Raw Coat Filter Render Element is similar to the Coat Filter Render Element, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection.
UI Path: ||V-Ray|| > Render Elements > Raw Coat Filter
width
5%
width
38%
Multiexcerpt include
MultiExcerptName
AddBackground
PageWithExcerpt
Atmospheric Effects RE
Image Removed
How to add a render element to a scene
width
57%
Enable Deep Output– – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in theColor mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post render color adjustments made from the VFB.
