This page provides information on the Corona Volume Grid, its settings, and usage examples.
floatingpagetoc
width55%
The Corona Volume Grid allows you to render objects which are truly volumetric and based on a 3D grid, as opposed to meshes with the Corona Mtl or Corona Volume Mtl which always require some kind of surface consisting of polygons to display the volume.
The typical uses of the Corona Volume Grid are fire, explosions, smoke, clouds, steam, and other visual effects based on particle or fluid simulations, objects which are not possible or hard to render when using classic polygonal mesh.
UI Expand
titleUI Path: ||Command Panel|| > Create > Corona > Corona Volume Grid
Command Panel > Create > Corona > CVolumeGrid.
width5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/eHjAM4Hz8hk" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
