This page provides information on the Blend Material.
Anchor | ||||
Example Workflow
Example: Blend Amount
The following examples shows the effect of the Blend amount texture on the render.
Here are the rendered results. In the first slider, the same blend amount texture is used with different Blend amount values. In the second slider, different blend amount textures are used and all of them have a Blend amount value set to 100%.
Section | |||||||||||||||||||||||||||||||||||||||||||||||||
The VRayBlendMtl has two Coat layers here and the blend amount textures control how each layer contributes to the final image.
Here are the render results.
Anchor | ||||
Example: Additive Mode
The following example shows the effect of the Additive (shellac) mode on a render.
And this is how the image looks when two Coat layers are used with 2 different blend amount textures - one Falloff and one VRayBitmap.
Anchor | ||||
Example: Additive Displacement
The following example shows the effect of the Additive Displacement option on a render.
Fancy Bullets | ||
