The Extra Texture (ExtraTex) Render Element shows the rendered image with a single texture applied to all objects in the scene. The texture applied to the scene can be a bitmap or a procedural texture such as V-Ray Dirt or or V-Ray Curvature.
A common use for V-Ray ExtraTex is to use V-Ray Dirt as the texture, which creates an ambient occlusion element for use in the composite. In this way, ambient occlusion can be controlled separately during the compositing process.
UI Path: ||out Network|| > V-Ray Render Elementsnode > V-Ray > Render Channel > V-Ray ExtraTex (RE)
