changes.mady.by.user Gergana Lilkova
Saved on Nov 17, 2021
changes.mady.by.user Kristina Gaytandzhieva
Saved on Dec 05, 2022
The V-Ray UVWGenObject node UVWGenObject node allows you to use Object mapping within the Mat Network.
UI path: ||mat Network|| > V-Ray > Texture: Mapping Mappings > V-Ray UV Object
Image Removed
Image Added
UV Derivatives Scale – Specifies an additional scale factor for the texture derivatives.
