UI Text Box | ||
This is an Advanced Level tutorial. The workflow for setting up the shot, and the Phoenix settings involved in the simulation are explained in detail. However, creating a production quality shot of a similar nature may require some tweaks to the it's recommended that you have at least basic knowleage in lighting, materials, and /or the Phoenix simulation. |
Section | |||||||||||||||||||||||||||||||||||
Units Setup
Scene Layout
Scene Setup
Solidifying with a Particle Tuner
Camera & Light
Materials for the Rocks and Ground
Material for the Solid Lava
Material for the Liquid Lava
Complete the Lava Shader
Mesh Smoothing for the Lava Mesh
V-Ray Frame Buffer
Final Results
