Enmesh
In order to use V-Ray Enmesh, you will need a pattern that is repeatable. After that you need to select your pattern and create an Enmesh object. Now all you need to do is to select the object we want our pattern to be spread on. In this videos you can see how is V-Ray Enmesh used.
Section | |||||||||||||||||
