width55%
The Color Channel node is a utility node that extracts only one color channel out of a given texture.
width5%
width40%
Properties
width55%
Input ColorSpecifies a color, from which the channel will be is extracted.
Multiplier A multiplier for the color intensity after extraction.
Mode – Specifies which channel is extracted from the texture: Red, GreenBlue, Alpha, Intensity.
width5%
width40%
