The Two Sided Material node is an output or Colored node. All other shading nodes can be inputs to this node. The Two Sided Material allows two surface nodes to be set as inputs, whereas the Material allows only one surface node.
UI Text Box
type
tip
Keep in mind that the Two Sided Node Material is shown in the UI as 2Sided Node Material.
width
35%
width
30%
Image Added
width
35%
width
5%
width
38%
width
57%
Front – Back – The material which is used for front-V-Ray uses for back side faces, as defined by the object their normals.Back
Front – The material V-Ray uses for back which is used for front-side faces, as defined by their the object normals.
Translucency – Determines which side (front or back) relative to the camera is more visible in the rendering process. By default this value is 0.5, which means that both the side facing the camera, and the one facing away from it, is are visible to the same degree. When this parameter is closer to 0.0 the 0, more of the material facing the camera is going to be seen. When it is closer to 1.0, the more of the back material is seen.
Force Single-sided Sub-materials – When enabled (the default), the sub-materials renders render as one-sided materials. Turning this option off is not recommended.
Multiply by Front Diffuse – When enabled, the translucency Translucencyis multiplied by the diffuse of the front Frontmaterial.
width
5%
width
38%
Image RemovedImage Added
Options
width
57%
Material Id Enabled – Enables the use of Material ID.
Multimatte ID – The integer ID of the material to be used by the "Multimatte" Multi Matte render element.
Round Edges Enabled – Enables the round edges Round Edges effect, which uses bump mapping to smooth out the edges of the geometry during render time.
Radius – Specify a radius (in world units) for the round edges Round Edges effect. Since the actual geometry is not being changed and only the normals of the faces are affected, large values here may produce undesirable effects.
Consider Same Object Only – When enabled, the rounded corners are produced only along edges that belong to the same object, which has the attribute applied. When disabled, rounded corners are also produced along edges formed when the object with the attribute intersects other objects in the scene.
Corners – Choose which edges are considered in the calculation. Possible options are:
Covex and Concave– Considers all edges. Convex Only – Only applies Round Edges effect to edges with convex angles. Concave Only – Only applies Round Edges effect to edges with concave angles.
