Common Uses
The Subsurface Scattering Render Element is useful for changing the appearance of SSS2 elements, after rendering, in a compositing or image editing software. Below is an example of its use.
Section | |||||||||||||||||||||||||
In the example, the scattering color is changed to red using the SSS2 RE. See the render before and after compositing.
Before after | ||||||||||
Compositing Formula
The VRaySSS2 Render Element is added to the Beauty render composite to form the final image.
