Compositing Formula
The Extra texture Texture Render Element is useful for changing the appearance of a render in a compositing or image editing software. The example below formula uses a VRayDirt texture with its Radius parameter set to 300cm 100cm and Subdivs set to 6.
Section | |||||||||||||||||||||||||
The ExtraTex is blended using Multiply mode.
