width45%
Any texture can be replaced via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
UI Text Box
typetip
You can search for a specific texture within the Search Scene field.
UI Text Box
typenote
The Bitmap texture settings are organized in Basic and Advanced modesBasic and Advanced modes. You can switch the mode from the toggle button () under the Preview the Preview Swatch.
width5%
width50%
