width60%
The Color Correction texture enables various color corrections to be applied.
UI Text Box
typetip
To color-correct a specific texture using a Color Correction, simply right-click on the texture slot to bring up its context menu select select Wrap In and In and choose Color Correction. This will place places the existing texture within Color Correction and then plug a Color Correction and then plugs it in the original slot.
width5%
width35%
