V-Ray for Revit adds a number of geometry objects and tools for use. See the links below for more information.
Geometry objects and tools are available from a number of places in the user interface. Each of the V-Ray geometry types has their respective icon.
UI Text Box | ||
Creation of geometry is available from two places in the Asset Editor: the Create Asset button and the Geometry category icon (top). If the Geometry category is empty, left-clicking the icon prompts you to create a new asset. Otherwise, it selects the category in which case, right-click opens the creation menu. The Asset creation dropdown lists remain active when the the Ctrl key key is held, allowing the creation of multiple assets in quick succession. The Asset creation dropdown lists can be activated via the Create Asset button the Create Asset button or the Asset Category icons. Geometries are assigned n the Material and Families tabs of the Appearance Manager. |
UI Paths
Section | |||||||||||||||||||||||||
