The Custom Color Render Element is a generic render element container used for referencing other render elements of type RenderChannelColor containing color information.
UI Path: ||Display Render Settings button|| > Render Elements tab > Custom Color
UI Text Box
type
info
To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu.
For more information on the parameters on this dialog, see the Render Elements tab page.
width
5%
width
33%
Multiexcerpt include
MultiExcerptName
RE
PageWithExcerpt
Render Elements
width
62%
Enable – When enabled, the render element appears in the V-Ray Virtual Frame Buffer.
Alias – Specifies an identifier for the render element. This can also be used to reference other render elements through their Vray Alias [vrayRE] attribute (found in Extra Attributes rollout; not the cleaner Extra VRay Attributes rollout).
Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.custome_color.vrimg).
Apply color mapping – Applies the color mapping options specified in the Color mapping rollout of the VRay tab in the Render Settings window to this render element. This option is enabled by default.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler rollout in the VRay tab of the Render Settings.
UI Text Box
type
note
This render element is not supported with V-Ray GPU rendering.
