width62%
The VRayPlaceEnvTex is a placement node that controls the placement of environment maps. It is automatically created when a texture is assigned to a VRayLightDome.
The example on the right shows an HDRI connected to a VRayDomeLight using a VRayPlaceEnvTex node to control the image's rotation.
UI Expand
titleUI Path: ||Hypershade|| > Create panel > VRay section > Utilities > VRay Place Env Tex
Image RemovedImage Added
width5%
width33%
