width57%
The Color Correction color node enables the application of various color corrections to a texture map (Bitmap).
width5%
width38%
Properties
width57%
Source Color – Specifies a bitmap to be color corrected.
width5%
width38%
Image RemovedImage Added
Channels
width57%
Rewire Red/Green/Blue/Alpha – Replaces the current channel with the chosen one:
Red – Assigns the red channel.
Green – Assigns the green channel.
Blue – Assigns the blue channel.
Alpha – Assigns the alpha channel.
Redinv – Assigns the inverse value of the red channel's value.
Greeninv – Assigns the inverse value of the green channel's value.
Blueinv – Assigns the inverse value of the blue channel's value.
Alphainv – Assigns the inverse value of the alpha channel's value.
Monochrome – Sets the channel to be monochrome (grayscale).
One – Assigns the value 1 (or the highest possible value) to the channel. For example, Rewire Red set to One gets the red channel a value of 255 (RGB, 0 to 255).
Zero – Assigns the value 0 (or the lowest possible value) to the channel. For example,
Rewire Red set to Zero gets the red channel a value of 0 (RGB, 0 to 255).
width5%
width38%
Color
width57%
Hue Shift – Specifies a value for the adjustment of the current color hue.
Saturation – Specifies a value for the saturation or desaturation of colors. Negative values desaturate.
Hue Tint – Specifies a color that is used to tint the current colors.
Tint Strength – Adjusts the strength of the hue tint Hue Tint.
width5%
width38%
Lightness
width57%
Lightness ModeSpecifies the lightness mode that is used. You can choose between Standard and Advance mode.
BrightnessAdjusts the overall brightness of the image.
Contrast – Adjusts the contrast of the image.
Exposure Mode – Specifies the exposure method: Gain, F-Stop or Printer Lights.
BrightnessAdjusts the correction of the color multiplier.
Gamma/ContrastAdjusts the color contrast or the gamma.
BaseAdjusts the correction of the contrast base.
Offset – Adds an offset to all pixel values.
Use Red/Green/Blue – When enabled, uses the corresponding channel for the advanced RGB parameters.
RGB Brightness
RGB Contrast –
RGB Base –
RGB Offset –
Printer Lights per Stop – When Printer Lights Exposure Method Mode is enabled, it specifies the number of printer lights equivalent to one f-stop. This is the required value to double or halve the exposure.
width5%
width38%
