Space – Controls how the texture is positioned on the geometry.
UV (2D) – Uses the object UV coordinates to map the effect. Texture – Uses an external UV placement source to map the effect.
Color 1 – Controls the color of the main surface.
Color 2 – Controls the color of the splatters.
Size – Controls the scale of the procedural texture produced.
Iterations – Controls how many times the procedural repeats the process of creating splatters.
Threshold – Controls how much of the texture is covered by splatters.
Smoothing – Controls the sharpness of the splatters. Lower values make the splatters sharper, and higher values make them more blurry.
width
5%
width
40%
Image Added
Context
width
55%
Context – Allows the attachment of a Context node (UVW generator) to adjust the UVWs of the texture. For more information, visit the Context Nodes page.
