Section | ||||||||||||||||||||||||||||||||
Anchor | ||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Bloom / GlareBloom / Glare
The Streak blur option is located under the Aperture shape rollout. It can be edited only when the Blades checkbox is enabled.
Obstacle Image
Example: Obstacle Images
Size (constant) = 50
Bloom (constant) = 0.5
Filter Image
File Names of Saved Channels
As expected, channels will Channels keep their names as displayed in the VFB when saving them to a single .vrimg or or .exr file (using the Save all image channels to single file VFB button). The same channel names will be are appended to the files, when you use the VFB button Save all image channels to separate files.
Fancy Bullets | ||
