width57%
The Two Sided Material node is an output or Colored node. All other shading nodes can be inputs to this node. The Two Sided Material allows two surface nodes to be set as inputs, whereas the Material allows only one surface node.
UI Text Box
typetip
Keep in mind that the Two Sided Node Material is shown in the UI as 2Sided Node Material.
35%
width40%
Image Added
width30%
Image Removed
width35%60%
width5%
width38%
