This page provides information about the Convert V-Ray 3 scene tool in V-Ray for Cinema 4D.
width57%
The Convert V-Ray 3 scene tool allows you to convert old V-Ray scenes created with previous versions into functioning scenes with V-Ray 5.
By default, if you open a scene created with V-Ray 3, V-Ray will ask you how to handle the file. If you skip this prompt, you can find the same tool from V-Ray > Tools > Convert V-Ray 3 scene.
width5%
width38%
width80%
Image Added
width20%
Image Removed
Options
width57%
Render Settings
Replace existing V-Ray 3.7 with new defaults – Replaces all options with V-Ray 5 default setup.
Convert all compatible options – Converts all old options that are compatible to V-Ray 5 options.
Scene elements
Convert all compatible optionsConverts all old elements that are compatible to V-Ray 5 options.
Remove all V-Ray 3.7 scene elements – Removes all old scene elements that are not compatible with V-Ray 5 from the scene.
width5%
width38%
