Before after | ||||||||||
Assets
Note that the Cosmos geometry is imported as VRayProxy. You can refer to the V-Ray Proxy page for additional information.
type | info |
Similar to the new Proxy node, newer Cosmos assets allow their shaders to be previewed and overridden in
the Object Hierarchy
of the V-Ray Proxy. Any material in the scene can be used to override the shader and allows for quick customizations of the scene. You can find the newest assets in
the What's
new section of the Cosmos browser. You can refer to the V-Ray Proxy page for additional information.
UI Text Box | ||
If you are editing a scene created on a different machine, or somehow your Cosmos assets are mislocated, you can use the Check for Missing Cosmos Assets tool in the V-Ray Tools menu. |
Lights
Cosmos lights are imported as a group, paired with the VRayProxy. This helps when moving or rotating the geometry, to keep its VRayLight together with it.
The HDRI assets create a Dome Light with the hdri file attached to it.
UI Text Box | ||
It is recommended to use VRayPhysicalCamera when using Cosmos hdri files for lighting. Alternatively, you can lower the dome light intensity. |
Materials
Section | ||||||||||||||||||||||||||||||||
Fancy Bullets | ||
