V-Ray for Cinema 4D
Old Version
1
changes.mady.by.user
Kristina Gaytandzhieva
Saved on
May 18, 2023
compared with
New Version
2
Saved on
May 18, 2023
Next Change: Difference between versions 2 and 3
View Page History
This line was added.
This line was removed.
Formatting was changed.
width
1%
width
24%
Thumbnail
ThumbnailTitleText
Chaos Scatter
ThumbnailBGImage
ThumbnailPageLink
https://docs.chaos.com/display/
VC4D4EDIT
VC4D
/Chaos+Scatter
width
1%
width
24%
Thumbnail
ThumbnailTitleText
V-Ray Profiler
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/Profiler
width
1%
width
24%
Thumbnail
ThumbnailCreditsText
©Mathieu Aerni
ThumbnailTitleText
Bump to Glossiness
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/Bump+to+Glossiness
width
1%
width
24%
Thumbnail
ThumbnailTitleText
Toon Material
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/Toon+Material
width
1%
width
4%
width
20%
Thumbnail
ThumbnailTitleText
Light Decay
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/Rectangle+Light
width
4%
width
20%
Thumbnail
ThumbnailTitleText
VFB Improvements
ThumbnailBGImage
ThumbnailSubText
Masking for the Lens Effects layer and the Denoiser
ThumbnailPageLink
VC4D4EDIT
VC4D
/Layers
width
4%
width
20%
Thumbnail
ThumbnailTitleText
Faster and better GPU renders
ThumbnailBGImage
ThumbnailSubText
with Compressed textures and NVIDIA AI Denoiser upscaling
ThumbnailPageLink
https://docs.chaos.com/display/VC4D/V-Ray+Tab
width
4%
width
20%
Thumbnail
ThumbnailTitleText
New User Attributes for the Cryptomatte RE
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/Cryptomatte+RE
width
4%
width
4%
width
20%
width
4%
width
20%
Thumbnail
ThumbnailTitleText
Viewport Interactive Rendering (IPR)
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/Viewport+Interactive+Rendering
width
4%
width
20%
Thumbnail
ThumbnailTitleText
Enhanced Procedural Clouds
ThumbnailBGImage
ThumbnailPageLink
VC4D4EDIT
VC4D
/V-Ray+Sun
width
4%
width
20%
width
4%
