Section | |||||||||||||||
Mode
On Render End
Anchor | ||||
Example: The Subdivs Parameter
The The Subdivs parameter parameter controls the number of rays that are shot into the scene, and the "noise" quality of the light cache samples.
Anchor | ||||
Example: The Sample Size Parameter
The The Sample size parameter parameter controls the size of the individual light cache samples. Smaller values produce a more detailed lighting solution, but are noisier and take more RAM. Larger values produce less detail, but take less RAM and may be faster to calculate.
Section | ||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Path Guiding
Both examples compare renders with both enabled and disabled path guiding and adaptive dome lighting. The results are shown using the Sample Rate render element.
See the Path Guiding with Intel® Open PGL in V-Ray article or more information.
Mode
On Render End
Example: Retrace Threshold
Fancy Bullets | ||
