width57%
The V-Ray Toon Material Node helps create 2D cel and cartoon effects. Use this material to make your scene get that hand-drawn look. Controlling the shadows and lights received by the material in combination with material transparency, gotten from Object or Material IDs, allows for fine-tuning the result. You can take advantage of the other standard V-Ray material options such as reflection, refraction, anisotropy, subsurface scattering and bump/normal mapping to set up the render to your liking.
Combine with the V-Ray Toon Volumetric to add custom outlines for an inky effect. NOTE: V-Ray Toon Material Node works best with V-Ray Legacy Lights.
width5%
width38%
