Processor | Intel* 64, AMD64 or compatible processor with SSE4.2 support |
RAM | Minimum 8 GB RAM, recommended 16 GB RAM |
Hard Disk Space | minimum 2GB, recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported |
Operating System | Windows 10, Windows 11 |
SketchUp | SketchUp 2019, 2020, 2021, 2022, 2023 |
GPU Support | Maxwell-, Pascal-, Volta-, Turing- and Ampere- based NVIDIA card(s) with latest recommended video driver
V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities. |
Processor | Intel 64, AMD64, ARM or compatible processor with SSE4.2 support |
Operating System | Apple® macOS 10.14.x 15 Catalina or higher |
UI Text Box | ||||
V-Ray GPU is not officially supported on macOS. It works only with C++/CPU devices. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s). |
