width60%
The Color texture allows a flat color to be assigned as a texture.
UI Text Box
typetip
Any texture can be replaced via the Replace With New Texture () button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
width5%
width35%
UI
Paths
||V-Ray Asset Editor|| Textures > Textures (right-click) > Color
||V-Ray Asset Editor|| > Textures Create Asset (left-click) > Textures > Color
Color
width60%
Color – Specifies a color to be used as a texture.
width5%
width35%
