width60%
This rig consists of a Dome Light source and a background texture. By default the background is not visible.
This rig is ideal for image-based lighting. Loading a spherical texture will automatically give you direct light, global illumination, and reflections based on the image.
UI Text Box
By default, there is an HDRI map loaded in the V-Ray Light Rig Dome.
width5%
width35%
Input Parameters
Light On On (Boolean) – Enables the Dome Light. Even when this option is disabled the texture remains visible in the background.
Rotation (Number) – Horizontally rotates the Dome Light.
File (Path) – File Path to the texture map.
