The Direct Light Render Element stores direct light and diffuse color information.
Section | |||||||||||||||
Attributes
Common uses
The Direct Light Render Element is useful for changing the appearance of direct illumination after rendering in a compositing or image editing application. Below are a couple of examples of possible uses Below is an example of a possible use, where the lights are warmed in compositing.
Sectionbefore-after | ||||||||||||||||||||
Compositing Formula
Raw Direct LightingLightx Diffuse = LightingDirect Light
