width50%60%
The Raw Global Illumination Render Element stores how much indirect lighting (reflected diffuse light) is received by surfaces in the scene. This raw element is useful for fine-tuning indirect lighting in the compositing process.
The Raw GI pass is untouched by the diffuse colors of the scene and represents the pure indirect lighting contribution. You can use this raw element to reconstitute the GI by multiplying Raw GI with the Diffuse.
UI Text Box
typenote
This raw render element must be rendered along with the Global Illumination element (Gl) for proper results.
UI Path: ||out Network||> V-Ray Render Elementsnode> V-Ray > Render Channel > V-Ray Color Channel (RE) > Type > Raw GI
width5%
width45%35%
Image RemovedImage Added
Attributes
width50%60%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel.
Consider For AA – When enabled, anti-aliasing is used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the V-Ray Renderer node.
Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present.
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width45%35%
UI Text Box
typeinfo
This render element is not supported with V-Ray GPU rendering.
Once the scene is rendered, the Raw Global Illumination Render Element is useful for changing the appearance of indirect lighting in a compositing or image editing application. Below are examples of its use.
width10%
width40%
Image Removed
width40%
Image Removed
Original Beauty Composite
width10%
See the Raw Global Illumination before and after editing and the resulting images.
width10%25%
width40%50%
Image Removed
Raised Raw Global Illumination Render Element
width40%
Image Removed
Raised and tinted Raw Global Illumination Render Element
width10%
width10%
width40%
Image Removed
Brightened GI
width40%
Image Removed
Tinted and Brightened GI
width10%
Image slider
Panel
borderStylenone
Image Added
V-Ray Raw Global Illumination
Panel
borderStylenone
Image Added
Original Beauty composite
Panel
borderStylenone
Image Added
V-Ray Raw Global Illumination edited
Panel
borderStylenone
Image Added
Beauty composite edited
width25%
Underlying Compositing Equation
Raw GI x Diffuse = GI
Image Removed
 Image Added
Fancy Bullets
typecircle
  • When Raw Global Illumination is needed in composite, please make sure to also render the Global Illumination render element (vrayRE_GI) as well.
  • This render element is not supported with V-Ray GPU rendering.
