This page gives some basic details about the Raw Total Light Render Element and explains how it is used in compositing.
width50%60%
The Raw Total Light Render Element is the sum of all raw light (both direct and indirect) in the scene, without any diffuse details.
This pass is useful for changing the appearance of the scene's light in a compositing or image editing application.
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Color Channel (RE) > Type > Raw Total Light
width5%
width35%45%
Image AddedImage Removed
Attributes
width50%60%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel.
Consider For AA – When enabled, anti-aliasing is used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the V-Ray Renderer node.
Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present.
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width45%35%
Image RemovedImage Added
UI Text Box
typeinfo
This render element is not supported with V-Ray GPU rendering.
Common uses
The Raw Total Light Render Element is useful for changing the appearance of the entire light lighting of the scene after rendering, using a compositing or image editing application. Below are a couple of examples of possible uses. The first two images show the render element itself and the Beauty render put together. The A V-Ray Cryptomatte Render Element is used to isolate the floor, the windows along with the curtains and the stone fence, and the ceiling. Then the Raw Total Light Render Element was brightened is brightened and tinted differently for each element to show the range of editing possiblepossibilities. See the render before and after compositing.
width10%25%
width40%50%
Image Removed
width40%
Image Removed
The Original Beauty Composite
width10%
Image slider
Panel
borderStylenone
Image Added
Original Beauty composite
Panel
borderStylenone
Image Added
Brightened Lights
Panel
borderStylenone
Image Added
Brightened and Tinted Lights
width10%
width40%
Image Removed
Brightened and tinted Raw Total Light Render Element
width40%
Image Removed
width10%25%
Underlying Compositing Equation
Raw Total Light x Diffuse = Total Lighting
Raw Direct Light Raw Lighting + Raw GI = Raw Total Light
Image Removed
 Image Added
