width50%60%
The Subsurface Scattering Render Element stores subsurface information from the V-Ray SSS material as an image. This render element can then be used to enhance or color-correct just the subsurface scattering component of the image during the compositing process.
UI path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Color Channel (RE) > Type > SSS
width5%
width35%45%
Image AddedImage Removed
Attributes
width50%60%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options  options in the render settings are applied to the current render channel.
Consider For AA – When enabled, anti-aliasing is used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the V-Ray Renderer node.
Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present.
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width45%35%
Image RemovedImage Added
Common Uses
The Subsurface Scattering Render Element is useful for changing the appearance of SSS items after rendering in a compositing or image editing software. Below is an example of its use.
width10%
width40%
Image Removed
width40%
Image Removed
Original Beauty Composite
width10%
width10%
width40%
Image Removed
Subsurface Scattering Render Element with the color of Subsurface Scattering changed
width40%
Image Removed
Color of Subsurface Scattering changed
width10%
Compositing Formula
SSS + Beauty = Final Image
Image Removed
In the example, the scattering color is changed to red using the SSS RE. See the render before and after compositing.
Before after
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing Formula
The SSS Render Element is added to the Beauty render to form the final image.
Image Added
