This page provides information on the Extra Texture render channel.
Section | |||||
Section | ||||||||||||||||||
Common Use
The ExtraTex Render Element is useful for changing the appearance of a render in a compositing or image editing software. The example below uses a V-Ray Dirt texture with its Radius parameter set to 100cm and Subdivs set to 6. The ExtraTex is blended using Multiply mode.
